Probably Dumb: Could I run a SMARTY w/ everything stock?
Could you run it at it's lowest setting and get away w/ it, with all stock? If not what would you need to add before the Smarty?
Yes, you can run stock but I suggest to you get gauges even though the smarty has low egt's for the power is produces it's just better to be safe than sorry.
If your planing on staying stock i would look to something else. Unless you plan on increasing your modifications why pay for all those setting if your only going to use one?
I dont plan on going crazy.... So, what do you suggest? I would like to blow away some of those rice burners around here!!
Sure you can, but its like a drug, you cant have enough.
And unfortunately, as long as you have money to burn, you do.
Id just get a decent air intake setup, straight pipe it, and the smarty and enjoy it
Smarty again.
You can see my signature. I'm carrying 2000# 24/7 on my back and with Smarty on #3,I'm seeing no egt problems at all. Stock clutch is doing well,and with Lorenz's suspension the truck is compliant but stable. You do really have to be shy with the go pedal in order to not soot out the guy behind you. New updates are coming out all the time to address us urban warriors. Definitely consider gauges for peace of mind.
Bushface
04-03-2006 02:47 PM
mr T
10-04-2004 09:06 PM
