View Poll Results: What is your primary compressor boost PSI?
18-22
0
0%
23-27
10.00%
28-32
40.00%
33-37
30.00%
38-42
20.00%
Voters: 10. You may not vote on this poll
Primary Boost or P/R
Twins only - what are you getting out of your bottom compressor? Please post turbo size, max primary boost and/or advertised P/R... wastegate info if the big turbine needs help. TIA
Thanks Terry - I was hoping you'd post up.
Isn't that about 100lbs/min through the primary?
Only working the top ~ 2:1 P/R? Remind me which secondary you have...
Jared, did you mean 28-32psi out of the S474?
Ever check your drive pressure up top?
S475 makes 32-34psi depending on the temperature. Feeds an HX-40 which puts right at 60 to the intake manifold. I run a 38mm external and the internal gate on the 40's 16cm2 housing.
DTR 1st Sergeant
The secondary is a hybrid gt4088r and is wastegated at 40psi.
The ratios vary throughout the range and depending on how I mash the pedal.
They will be heavy on the secondary side up to about 20 psi then they are both pushing the same air until about 55-60psi total then the primary starts pushing just a little more of the air load... but for the most part, it is 2:1 p/r and drive pressures stay at 1:1 (on both the secondary and primary) up to about 70-75 psi. At 80psi boost, overall drive pressure is about 90-95psi. I could run a larger EH on the primary and alleviate that, but it spools so darn fast I don't want to touch it.
With flux 1's, TST at 3/1 and Va3.1 (at low power) I see about 28psi on the primary at WOT. No studs so I haven't fueled any higher. That 28psi is about 50% of total boost, which seems to be the case from about 45psi on up. My primary is a GT4202 (non BB).
willieboy
04-01-2007 10:32 PM
WideOpenThrottl
12-15-2006 12:42 AM
apwatson50
09-07-2006 03:24 PM
12valve
05-03-2006 04:45 AM
northslope
04-23-2006 03:46 PM
