Predator Pressure Box Problem...
PREDATOR PRESSURE BOX PROBLEM... I took my predator of my 05 and put it on my other 05 and it doesent want to start. Any thoughts what would cause this..... thanks
I had two other buddy that had a 05 and it did the same thing. We were trying to put the dr performance same as the predator box. But at the same time I had a 05 and it had work in mine. If you check his truck it throws a bunch codes to so you should check see if there are any codes. For some reason it work in some and don't work in other.
bsj04
0
08-20-2007 10:44 PM
04ctd
10-05-2006 08:27 PM
