predator, power puck stack?
i just my predator in and on the performace tunes it as both the predator and power puck tunes does that mean it has both of the tunes?
It should of came with, from the "factory":
tow
performance
extreme
tow stacker
If you want other stack programs, you will have to download them from diablo's website. Then, I am not sure what they have for the 06's.
tow
performance
extreme
tow stacker
i thought there was a factory extreme stacker,im sure mine has one,do u have guages?ifnot dont use anything above performace,diablo tunes get real hot as they use a lot of duration not timing.and make sure ur pred is updated to the very latest from diablos site,your truck is new with waranty and u dont want to deal with the keycount thing,i think they have it fixed on the new version
Mine had two options before you chose the tune, first you had to choose stack or non-stack tune, then you chose which tune you wanted. If it gives you both options it thinks that you have the puck installed, when my puck was not installed it would not give me the stack programs.
mine had 2 categories. It had power puck tunes, and performance tunes. I never ran the puck, but i'd at least upgrade the lift pump, and get either a clutch or build up your tranny some before using it.
Israel Sweeney
30
07-03-2008 01:39 AM
usmcduncan001
09-21-2007 12:31 PM
Dodgezilla
07-15-2007 11:18 AM
RAMnUTAH
13
05-01-2007 12:49 PM
rkelley
04-15-2007 07:54 PM
