Predator................................
i just got a switch for my predator and im a bit confused. the switch itself says "on off on" right on it.and the plate with the sticker says" tow performance off ". And the switch when its in the middle says its off but when you put it in the bracket it would be on performance setting.
I'm confused with your confusion. If you mount the switch upright (so you could read the positions) and put the plate with the sticker on it upright (so you could read the positions) it would make sense to me.
on = Tow
off = Performance
on = Off
Sounds like that is how Diablo engineers engineered it to work. Does it work?
on = Tow
off = Performance
on = Off
what do you guys think of predator. i have had bad luck with bullydog and superchip. really considering a predator. any comparisons. bad lick was with my torque convertor x3.
Are we talking diablo power puck or the dr. performance module diablo power puck just doesnt have the power for me even when stacked the dr. perf module was great lots of fuel on big end just kept throwing a pesky p0148 code and they didnt have a very good fix for the problem on the power puck towards the slit on switch end is the 90hp, center is off and other side is 50hp. Dr. Perf slit was 50hp, center was 110+ and other side was off. Hope this helps not sure what module you were talking about.
TruckTuner
30
08-03-2004 09:19 AM
Texas Crew'd
05-25-2004 04:44 PM
Scubasteve
12-13-2003 12:01 AM
