PPE vs Smarty on an 07????
Old 09-18-2007, 03:22 AM
darrenb's Avatar
PPE vs Smarty on an 07 5.9????
any info or data(dyno #'s) on the PPE Xcellerator? how does it rank against the smarty???? just curious
Old 09-19-2007, 02:55 AM
darrenb's Avatar
BUMP....
anyone got anything to share?
they claim 215hp increase! with those kinda numbers, i figured their might be some guys cheerleading for the PPE Xcellerator.....some sites claim over 300hp...????smarty beta is about a 190hp increase?????
Old 09-19-2007, 03:19 AM
01smoker's Avatar
PPE rates thier product at the flywheel, where as smarty rates thiers at the rear wheels. The beta is a 240hp increase at the wheels I believe.
Old 09-19-2007, 03:32 AM
darrenb's Avatar
hmm...ok.
what does a stock 2007 5.9 rate at the wheels?
and then...
what does a 300hp increase at the crank relate to at the wheels?(PPE hp claim)
Old 09-19-2007, 08:15 AM
tritont's Avatar
PPE doesn't work on the 07's. They haven't figured it out yet. Before you try and use any box with that kind of power, you should put the cash into the trans and other things that will back up the power.
Old 09-19-2007, 08:10 PM
darrenb's Avatar
hmm... a friend of a friend is currently running one on his 07 5.9 and really likes it know matter what he hears about the smarty.....
Old 09-19-2007, 08:25 PM
CReed's Avatar
PPE has a programer out for the 06-07 trucks they just dont have the hot versions out like they do for the 03-04 and 05 trucks yet, I was told last week it will be a few months on that as well. Dont know much about smarty but I have seen what a ppe can do and will awaiting the release of the ppe hot for my truck and it will be one of my many new purchases in the future.
Old 09-19-2007, 08:29 PM
tritont's Avatar
he may want to call PPE than because as of a couple weeks ago... they didn't know when they have it working correctly.
Sometimes vendors will sell a product whether it works for you or not. They maybe don't know themselves or are just moving product without caring.
This same thing happen with TST. They couldn't control who their vendors were selling to and many with 07's were calling them wondering why the broke something. They stopped selling for the after 6/06 build a long time ago.
People even called TST and lied about having a 07 just to get their box and ended up calling them back claiming they sold them a box for a 07 that blew up their engine. They knew better though.
Old 09-19-2007, 08:33 PM
Danderson's Avatar
These '07's are hard nuts to crack. Marco's got it down except for the smoke issues. Bob wagner indicates relief is on the way.
Old 09-19-2007, 08:34 PM
CReed's Avatar
The problem with the tst was with the injector harness if I am am correct. Everyone has a downloader that works on 06-07 trucks and their is nobody claiming before 06/06 only and then late after 06/06-07 trucks. Not smarty, bullydog, diablo, or ppe. If their is a problem their not going to admit it. What kind of problems did you hear about with the ppe on later built 06-07 trucks triton.
Old 09-19-2007, 11:36 PM
973604x4's Avatar
Programmed a Smarty on 9.....546hp to the rear wheels. Programmed PPE HOT while strapped to the dyno....580hp to the wheels. Nothing else changed.
Old 09-20-2007, 01:09 AM
ScienceOfSpeed's Avatar
well i know NADP has a some trucks in the 11s and they stack the PPE with the Dr.Performance Predator and it seems to be a good mix
Old 09-20-2007, 01:13 AM
jwb600's Avatar
my truck made 461 to the wheels. that was with a stock turbo, injectors etc.
only mods were a fuel system and built trans then. im sure someone out there dynoed their stock truck with a PPE I would think
Old 09-20-2007, 01:53 AM
PowerDually's Avatar
I am presently running the PPE Hot with a Dr P stage 3. I have to say that I like it best of all the items that I have used including just about everything except the smarty. Smarty is one item that I have not used yet.
It is smooth power throughout the rpm band and with the pressure it runs like champ and spools the 62/14/71 HTT like a champ.
I did figure out that the hot version has pressure in it and I was drowning the motor on the bottom end.
I downloaded the tow for pulling and it great on the bottom end.
Old 09-20-2007, 04:49 AM
darrenb's Avatar
which version of the smarty was that? beta??? and i'm sure others along with myself would love to see that dyno sheet......great numbers either way though!!
Quick Reply: PPE vs Smarty on an 07????
