Power Puck vs. XZT which to choose?
Old 05-14-2007 | 10:21 AM
06megacabman's Avatar
So I am just looking for something mostly to enhance towing and get a little more mpg. My truck is basically stock as shown in my sig below. I have searched the forums here on both but seems like most run the programmer/puck stack and/or the xzt.
Any advantages of one versus the other if running just the 65hp mode for both. From what I have read seems like the puck does injection timing and duration and the xzt box does a little of everything including pressure.
Anyone running just the puck? Any input is appreciated.
Old 05-14-2007 | 10:24 AM
After reading my post I thought I should clarify. I am NOT wanting to stack the puck and xzt. I am just trying to compare if I ran the puck only or bought the xzt box only if there is any difference or thing I should know.
Both have the 65hp/150tq mode I believe.
Old 05-14-2007 | 11:34 AM
qzilla's Avatar
I really think the biggest difference is that the puck does NOT do boost fooling. Other than that they should be similar.
Old 05-14-2007 | 11:47 AM
Hunter11's Avatar
I have the XZT box and would buy it on Quad's customer service alone. I love mine.
Old 05-14-2007 | 12:07 PM
RedRacer44's Avatar
I agree with Hunter11...Quadzilla's customer service is 2nd to none! Love my XZT by itself or stacked with the Triple Dog.
I had a Puck on my 2002 CTD and it gave good power and increased mileage though. On the flip side, about 15k after install...I had some issues with the truck and had to pull the Puck because it wouldnt run right with it on and got terrible mileage with or without it. Traded the truck off shortly after that
Old 05-14-2007 | 02:01 PM
$oC@l CTD's Avatar
I like my Puck pretty good...it gives a good amount of power down on the low end side of the house, but top end, you can't even really tell it's there...but getting things rolling such as a heavy load it what it was designed for, so it does it's job just fine. My mileage went up about 1 maybe 2mpg and as far as duration, timing, pressure...the Puck is all pressure and I am pretty sure that the XZT is as well, but I could be wrong on that one.
Old 05-14-2007 | 02:58 PM
973604x4's Avatar
for a pressure only XZT, you have to have the custom flash from Quad. a standard XZT has a little bit of timing....
Old 05-14-2007 | 03:34 PM
quadman20's Avatar
Let me know if you want to go with the quad box I, got one to sell. It's off my 06
Old 05-14-2007 | 06:31 PM
I just sent you a PM
Old 05-14-2007 | 06:33 PM
Is there any issues with running the XZT box or Puck with the Rokktech timing sensor?? I just ordered one of those over the weekend.
Old 05-14-2007 | 09:45 PM
gvflinn's Avatar
Have had the power puck for over 130,000 and it still works really well with good low end torque and pulling power. I pulled 10,000 for about 3 years in my 2000 2nd gen. Now it's been retired and only pulls a 21' trailer. I guess I appreciate the longevity and reliability. But, ultimately it's your choice as there are many good products out there.
I was looking at my power puck and the metal on the top even has some rust on it; but, it keeps on going.
Jerry
Old 05-15-2007 | 05:28 AM
Dodgezilla's Avatar
It will work well with the Rokktech. You may not be able to advance the Rokktech all the way due to timing rattle. You will know once you have them both installed. It should be a great combo....
tex23455
02-18-2008 08:57 AM
BIGDAN65
16
01-23-2008 11:02 PM
bluebull
11-10-2007 01:03 PM
Stainless
11-01-2007 11:53 PM
engcogod
04-22-2003 02:43 AM
