Powder Coated Wheels
Old 08-23-2007 | 01:54 PM
torkmnstr's Avatar
This goes out to all the powder coated rim guys. So I am thinking of getting my rims powder coated. I was wondering if it threw your tire balence off at all? Also, when getting your tires put back on did it effect the bead at all or did you just coat the face and not the inside of the rim. Any info would be appreciated. Thanks guys.
Old 08-23-2007 | 02:54 PM
SlowSixSpeed's Avatar
Are you serious....
Its a good thing you posted it HI PERFORMANCE 3rd gen
Don't do it!!! It will throw everything out of wack on your truck if you paint your wheels
Old 08-23-2007 | 02:55 PM
cquestad's Avatar
Mine where coated inside and out...
No problems at all. After several tire mounts...a slight line has worn through the coatign where the tire spoon spins...but it is out of sight.
GO FOR IT!
Old 08-23-2007 | 03:18 PM
torkmnstr's Avatar
Originally Posted by SlowSixSpeed
Are you serious....
Well slow.... well this is hi po and accessories and the last time I checked this process is an accessory, but as for the throwing it out of whack it is possible since you are adding extra layers of material over the rim and since I dont own an "electron microscope" how will I know it it is layered uniformly over the entire rim and not be thicker in some places than others leaving an out of balance rim. Oh and by the way it is not "painting" them, but powder coating them google it.
Old 08-23-2007 | 04:22 PM
82NDSNPR's Avatar
i dont think it will throw off the balance the amount that goes on there is nothing major heck a rock stuck in your tire tread will weigh more then the coating and for duribilty you cant beat the coating i coated my chevelle frame and 3 years latter with many passes down the 1/4 mile it still looks brand new what is the cost for your wheels??
Old 08-23-2007 | 04:38 PM
torkmnstr's Avatar
Not sure yet, some guys on here have had it done for about 50 bucks a wheel. All depends on the place I guess.
Old 08-23-2007 | 04:55 PM
nriver's Avatar
I had it done to some stock wheels. no issues with balance that I knew of. They just put the weights on.
Problems I ran into. To much coating on the inner hub ring. There is not allot of room there and my wheels had two coats on them. I was using a hand file to remove material at the tire shop.
I also ran into issues with the coating cracking under the lug nuts. Made the second coat start to peal. This may of been a problem with the application. But was still a pain for me.
Cost is around the 50 a wheel mark, depending on how much sand blasting the wheels need. Don't forget the 100 bucks to mount and remount the tires before and after the coating is done.
My last set of wheels I just painted. To me they look just as good and quite a bit cheaper. That and touch up will be easier. JMHO
Old 08-23-2007 | 04:56 PM
53 willys's Avatar
mine are done in and out too.. no problems here
Old 08-23-2007 | 07:25 PM
Danderson's Avatar
Powder coat!
My friend had it done while his truck was up at Carli's. Came out beautiful. No problems. Definitely toned down the bling. Off the thread,but my buddy just returned from a 1400 mile Baja trip. 2.5 King Performance system worked out great.
Old 08-23-2007 | 09:59 PM
XLR8R's Avatar
Powdercoating can get pretty thick - we have to allow for ~ .060" on the parts we fabricate. For wheels, the best thing is to mask off the center hole and lugnut seats (axle grease works well ) or remove the PC before mounting from those areas.
Old 08-23-2007 | 10:22 PM
jwb600's Avatar
Im thinking pretty hard about getting some stocks wheels powdercoated. I thought it would be alot cheaper than it is. I thought of just painting them but I figured it would scratch off when the tires are mounted
Old 08-23-2007 | 11:51 PM
nriver's Avatar
Just painted wheels, no issue when they mounted the tires on them. No scratches.
not to post more pictures, but my painted wheels.
Old 08-24-2007 | 02:27 AM
jaredb900rr's Avatar
Mine were done inside and out. The $50 per wheel price sounds about right. Like XLR8R said, have them mask off the center hole and the lugnut seats. The wheels went on fine, a little tight...but when I went to rotate them, I had a hell of a time trying to pry them off the hub. Ended up sanding them down a lil so they weren't so tight.
Jared
Old 08-24-2007 | 06:13 AM
H8GAS's Avatar
Let me know if you find a good place to do the powder coating in Santa Clara. I work there and have been thinking about doing this too.
Old 08-24-2007 | 07:47 AM
gpshemi's Avatar
I was thinking about having a set of chromes clear powder coated, but was informed he's having about a 50% suscess rate. Appearently the chrome bubbles off on about half of them he does. Bummer cuz it would be the perfect fix to keep those chromes looking good forever.
