View Poll Results: What guages are you running?
Manual
45
51.14%
Digital
21
23.86%
None YET
22
25.00%
Not Going To Install Any
1.14%
Multiple Choice Poll. Voters: 88. You may not vote on this poll
Poll: Digital or Manual Guages
I went with manual-electrics. Personally, I think they are easier to run, and specifically, you can switch the gague between multiple sensors.
Try to stay with sensors that have more than one wire. The one wire types use the engine or chassis ground for the voltage return path and can be subject to more errors in readings.
I used the Autometer NV series, that have 2 wire temp tranducer and 3 wire pressure transducers. The difference between a sensor and tranducer: Accuracy. A transducer will be MUCH more accurate. Technically, the singals used on the pressure tranducer: 5V reference, pressure signal, 5v return to the gauge. On the temp transducer: 5V reference and temp signal.
HTH
Tony
HTH
Tony
I voted for both, my boost and pyro are analog but both of my fuel pressure guages are digital. I bought them because they are small, about the size of the door lock remote and could be placed anywhere easily.
I'm going to purchase analog. While the digital seems more state of the art and functional, analog still seems to be the easiest to glance at and know if you are in trouble.
Digital would give a more precise reading if thats what is needed. It seems that for watching a trend the analog dial would be easier to monitor.
Also, "old eyes" see the dial pointers, especially in bright sunlight, better than led's.
i like analog gauges, but full sweep electronic analog gauges are not cheap.. i have autometer ultralites boost and egt for now. soon to add fuel pressure, lube oil pressure [to replace my cheap parts house one], lube oil temprature & air pressure [yeah air horns]
I think that a triple guage pillar LOOKS better, but I still prefer digital guages (I've had an X-monitor, Edge Attitude, and now soon a Commander). I like the warning features, as well as the MAX readings (or MIN) that get stored. Plus the Commander adds a whole slew of extra features.
I prefer to look at analog guages. But for the size of this dash, they sure don't leave you much room to mount them without getting ugly.
I went with the Commander.... I had to wait a while for it, but it seems to have been worth it. All the information I need in a fairly compact spot, and it can be set to scream at me if I'm not paying enough attention and things get out of hand and if I've got the radio up too loud and don't hear it, it will defuel for me.
I am hoping we can help close that Digital to Analog ratio!
We have another digital option that will be out for you guys that do not want anything too fancy, but need the function.
Should be out sometime the first week in August.
Before you ask, it is totally different than the Commander, with a totally different mindset. More info should be on the Web this week, or first of next week. If you look close there is a little hint of it on there now, but not enough to draw any conclusions!
Quad
Quad
im runing both right now, thought about putting the anologs in the mega cab , but im just going to buy another comander, i didnt think i would like the digital but it is so much eaiser to read
12valvedutchy
02-17-2010 09:21 AM
TORQUE BEAST
05-24-2007 12:36 AM
jrs_dodge_diesel
29
01-12-2006 04:21 PM
