which plugs in first?
i have a TST and just got an EZ. The EZ go into the map sensor then the TST into the EZ right?
And on the rail side the EZ to the rail then the Quad rail gauge to the EZ?
Thanks for any help!
Chris
Chris
I have mine just the opposit. MAP = TST first then EZ and then OEM. Rail pressure gauge should always plug into the sensor first to see actual sensor readings. Just my .02.
If you have an EZ, you want the TST first. The EZ caps boost at 18-21 or so psi, so some TST programs won't fully fuel (this was the case on my '03).
If you have a MP-8, you want it plugged in first as it tells the TST the manifold has more boost than it really does, giving you better bottom-end fueling. You wouldn't run the TST rail pressure settings, though.
Haulin_in_Dixie
14
01-13-2011 08:03 AM
Bradleysram
19
05-12-2009 08:36 AM
RyeThomas
34
10-13-2008 10:47 AM
TDRattler
08-07-2008 07:10 PM
