Plugging Off Factory Fuel Line After Installing FASS??
Old 11-05-2008 | 01:14 AM
dodgediesel's Avatar
Question Plugging Off Factory Fuel Line After Installing FASS??
Was just wondering if someone makes a banjo bolt plug for the bottom of the fuel filter canister?? I want to remove the fuel line from the CP3 to the bottom of the fuel canister to clean up the FASS install. Thanks guys...
Old 11-05-2008 | 01:30 AM
06RAM2500's Avatar
What you can do is tap the end with a fine thread bolt tap and cap it off with a small plug.
Old 11-05-2008 | 08:05 AM
Fisherguy's Avatar
I went straight to my CP3 with the new fuel line when I did my AD. I just drained the fatory filter housing then removed the steel fitting at the CP3 from the hose it attaches to and blew out the fuel line and taped the ends of the hose (engine and tanks ends) with electrical tape. I can use it again if I ever need to.
Old 11-05-2008 | 09:43 AM
True, true. I just wanted to clean it up after the install. I thought there might be some kind of blank Banjo get-up sold out there?
Old 11-05-2008 | 12:30 PM
kprc51's Avatar
I struggled with this since i installed my AD in January. Every time i filled my truck, fuel would drip through that fitting.
So on saturday I sacrificed the steel pipe and fitting that originally went to the CP3 from the filter housing, hammered the tube flat and put two rolled bends into it. Cut it nice and short so it looks decent. Re-installed the banjo bolt and the new "modified" fitting and tube and no leaks since saturday.
I think that ought to do it.
JR
Old 11-05-2008 | 12:54 PM
SINGLESTACK's Avatar
I took the steel piece that goes to the cp3 off the rubber hose the connects to the FF housing and put a SS bolt in it and hose clamped the bolt in the rubber fuel line and wire tied it out of the way.
Old 11-05-2008 | 04:01 PM
Those are some interesting fix's.
Old 11-06-2008 | 07:15 AM
tesla440's Avatar
Y not use a bolt to plug the housing?
Old 11-06-2008 | 09:19 AM
I'm guessing it would be a special type of bolt needed??
Old 11-06-2008 | 09:53 AM
XLR8R's Avatar
We use a filter delete block for those installations.
Old 11-06-2008 | 11:10 AM
What is that and where does a guy get one? Got any pictures please??
Old 11-06-2008 | 12:01 PM
BIGDAN65's Avatar
i got my filter delete from Glacier have not put it on yet though
Old 11-07-2008 | 02:35 AM
fuelmiser's Avatar
I got one from GDP also. Pretty expensive for what you get, but I didn't have time to build my own. It gave me just enough room for a 1R0749.
Old 11-07-2008 | 09:42 AM
Actually, I went to a local diesel repair shop and got these 12mm plugs designed especially for a plugging or capping off application. They were $5.00 a piece with the banjo washer. Worked like a charm. I guess I'll keep the old line just incase. Does a guy have to leave the old fuel canister full for the sensor to work properly in in or can I leave it empty?
Old 11-07-2008 | 04:35 PM
Festus's Avatar
Originally Posted by dodgediesel
Actually, I went to a local diesel repair shop and got these 12mm blugs designed especially for a plugging or capping off application. They were $5.00 a piece with the banjo washer. Worked like a charm. I guess I'll keep the old line just incase. Does a guy have to leave the old fuel canister full for the sensor to work properly in in or can I leave it empty?
I drained mine and blew it out with shop air.......so far, so good.
