PLEASE HELP...Will these wheels work?
Old 07-17-2004 | 10:20 AM
PADZZ's Avatar
18" Weld
I'm now convinced I need some wheels and tires. Could I get these wheels to fit on my truck w/ just a 2" level up front, also, what tires have been working with 18" on our trucks? I'll be pulling about 11K lbs of 5th wheel.
Thanks.
Old 07-17-2004 | 12:43 PM
phox_mulder's Avatar
They have the same backspacing as my Welds, and the same width, so expect them to stick out 2-3 inches, depending on the tire you put on them.
Don't know if the 3rd gens have the same rub problem when going to a 10 inch wheel,
expect them to rub the rear inside of the fender at full steering lock (with a 35 inch tire)
Put a 305 (33 inch tire) on there, and they should work nicely.
No idea what is available in an 18inch tire, but pulling that weight, make sure they are E rated.
phox
loanman
11-27-2008 11:11 AM
highgun
06-09-2008 11:14 AM
TravisDj
12-09-2007 01:56 AM
Firstgenfanatic
11-14-2007 12:03 AM
Cummins600
12-17-2004 03:44 PM
Quick Reply: PLEASE HELP...Will these wheels work?
