Please Help! What size Drill and tap for my Pyro install?
I am seeing many things. I bought the kit from Diesel Manor which are the Di Pricol Optix series. What size drill bit and tap do i need to use??? Thanks, Jason
Do a search, more info there than god has
Also we don't know what size thread your gauges has. If it's 1/8" NPT then you need a 1/8" Tap, if it's 1/4" then you need a 1/4" Tap. Also the taps will decide what size drill you use.
Let us know what size it is, and we'll help you
i e-mailed DM...ive searched but i guess i wasnt fully understanding what was being said...i think i have it figured out now tho..thanks guys..
Best bet is to look at the side of the tap. A quality tap will tell you what size pilot hole to drill. It is usually a 1/64 or 1/32" number. The standard size bit will work but using the correct pilot hole helps reduce the chance of a leak. Dont forget to put a little antisieze on the threads before inserting your new pyro incase you need to pull it one day.
LovinTheTorque
09-14-2013 12:02 PM
Tim Frederick
10-06-2007 02:09 PM
Big Smoky
06-28-2007 11:03 AM
Dodgezilla
08-22-2004 06:12 AM
