Plans for a under-seat sub box?
Old 01-18-2009, 09:00 AM
Ram Daddy's Avatar
Cool
I just recently added the MTX Thunderform amplified box to my stock Infinity system , and couldn`t be happier.
Ended up paying $420 to my door for it ,and it took less than an hour to intall it , and that included unpacking it , and removing the fold flat bottoms
and interior trim to run the wires.
It has 2 10s and an amp mounted inside the box , a built-in crossover , and a remote bass **** that lets you control the amt. you like from the drivers seat.
...and it looks stock , and can easily be removed and put back to stock.
You do however , loose the inside storage , but I bought a small lockable heavy duty black storage container from Sams for under $25 and put it in the bed , to hold the few items I had inside the truck....yes I guess someone could steal it , but it`s under my bed cover out of sight , probably the same chances of the truck being broken into.
Old 01-18-2009, 03:45 PM
Bowser50's Avatar
I wanted to know how you raised the seat, did you have a spacer made? or did you buy one?
Old 01-18-2009, 03:52 PM
Nate-03 D's Avatar
Do you have any more info on the MTX Thunderstorm setup? The subs came in a pre-made enclosure?
Old 01-18-2009, 04:00 PM
Bowser50's Avatar
where did you find that MTX setup, and are the subs MTX subs or are they a different brand?
Old 01-18-2009, 04:02 PM
Ram Daddy's Avatar
Question
Yep , everything was included.
I`m guessing they have a website MTX.com(?)
..and yes they are MTX subs.
Don`t get me wrong , if you`re looking for earth pounding , glass shatering boom , this isn`t for you...but it does put out great all around bass.
Old 01-18-2009, 04:09 PM
Nate-03 D's Avatar
So all you had to do was drop in the enclosure and wire it up?
I' m already running Kenwood speakers and a Kenwood Headunit, i 'm looking for a little more punch now.
Is your system really "bassey" or is the sound real clear? I believe in clarity before bass, if I can't understand what im listening to whats the point right?
Old 01-18-2009, 04:27 PM
Bowser50's Avatar
Yeah i just want something that can shake the inside a little bit and give a little more kick, I noticed that the MTX setup is rated to 450w so if I went with an 800 w amp I should get some pretty good sound out of the subs. and also I don't know if I have the seven speaker or the 4 speaker factory system but was wondering about the tweeters in the dash.
Old 01-18-2009, 04:28 PM
Bowser50's Avatar
where are the tweeters or 3 other speakers at in a 7 speaker system?
Old 01-18-2009, 05:21 PM
Price_Dog's Avatar
I believe there are three in the dash, and four in the doors?
Old 01-18-2009, 06:12 PM
03dodgeoffroad1's Avatar
i made a spacer out of 3 inch C channel drilled holes and got longer bolts you couldnt tell if you werent looking
Old 01-18-2009, 07:44 PM
Blake Clark's Avatar
Best bang for you buck....
http://www.foxacoustics.com/SearchResults.asp?Cat=23
you can get 10's or 12's in sealed or vented configs and these are the most efficient boxes on the market with the largest airspace availble.
Old 01-18-2009, 08:26 PM
stroker101's Avatar
"crutchfield" also sells the mtx box loaded with 10" speakers and amp. kinda pricey.
the local stereo shop here had everything to install. i have 12" subs with the remote bass gain up front
Old 01-19-2009, 07:57 AM
Swayse's Avatar
I second that.
Old 01-19-2009, 09:32 AM
cquestad's Avatar
musicmooseaudio.com is a great solution...
I have (2) Infinity 10" Kappa's in one truck and (2) Infinity 10" R's in the other.
Old 01-19-2009, 03:09 PM
Ram Daddy's Avatar
Cool
Yes , I think there was the RCA cables , power cable , ground and remote turn on to hook up...and everything was included.
No , it`s not "bassey" , at all. One of the cool things about it is the remote bass **** , because you can fine tune it , or turn it up/down from the drivers seat.
...and yes , Crutchfield wants a LOT more than what I paid for mine....like $650 or something , for that amt. I would have done a custom enclosure.
leeboy
0
12-27-2012 11:28 AM
AKsmoke
13
09-11-2010 12:11 PM
Johnny RAM
09-24-2008 07:40 PM
MoparNut
15
09-19-2008 08:40 PM
Scotty
08-30-2004 11:12 AM
Quick Reply: Plans for a under-seat sub box?
