piller gauges anD dash mounting...
after all not sure I want to cut the piller handle out... but do love the way the piller mounting looks... sooooooooooo.. may do the double lower piller mount like the SVT-10?? and then do a single or double dash unit...
question is hows does the dash unit look..work... anyone have one... setup may be.
piller #1 digital SPA daul EGT (pre and post) that way all covered
piller #2 boost (maybe Di Pricol)
dash #1 fuel pressure
dash #2 if use a double.... oil temp...
any comments...
any comments...
If you wait a little longer there will be two "new" options for multiple gauge mounts retaining the OEM piller handle. Pictures should be availible by the end of the month from Scotty.
A Pillar mount that doesn't require cutting the handle!
ckennedy,
We have a "Replacement" A pillar for 2 or 3 gauges that doesn't require you to cut up the handle at all. You actually remove the factory A pillar and bolt ours back on, it's moudled in the factory material in the factory Taupe color with the factory grain. The gauges are set into the mount deeped so they don't stick out so far like A pillars that go on top of the factory A pillar. No painting, bolts on, looks OEM!
Mark @ DPPI
Mark @ DPPI
Hi, I got a 3 gauge pod on my dash. I needed gauges about a year ago and would not cut my grab handle.
I ended up taking a dash gauge pod for a gen 2 and mod it to fit my 2003 gen3 dash.
painted to factory dash color, right in between defroster vents in center of dash. looks pretty good to me. actually the line of sight is really pretty good.
I see now that they have a gen3 dash pod out now, so you wouldn't have to mod the old pod to fit like I had to.
consider that as an option if you are like me and really want to keep the grab handle.
NoSparkplugs
17
05-17-2009 10:36 PM
98silver12v
10-07-2007 10:18 PM
raw122
05-30-2007 07:06 AM
03CTDCO
06-13-2005 09:10 AM
