A-pillar install
A-pillar install
Getting ready to add a tranny temp gauge and mount it on the a-pillar. What am I supposed to do about the grab handle? Somebody told me awhile ago that the only way is to cut the handle off. Hince the reason I mounted on the steering column, but I really need the tranny temp gauge and I think the a-pillar looks the best. Can anyone help plz?
It depends on which pod you get. Some of them are nothing more than a cover. With those, you have to cut the handle off and then put the cover/pods on.
However, there is one available that is a REPLACEMENT and it is made of the same materials and by the same manufacturer as the folks who made the grab handle. It is also molded in the correct color. You can get it HERE or at Diesel Manor. It is available for 2 gauges or 3 gauges....or if you just have 1 gauge you can get the SRT pillar and keep the grab handle.
cantfindaname,
DO NOT cut up your stock A pillar, the one HOSS mentioned replaces the stock one and bolts right on, they are available in 2 or 3 gauge designs and are molded out of the same material as the stock one from the same material supplier, they look great! Call us if you have any questions etc.
Mark @ DPPI
Mark @ DPPI
drewallen42
04-14-2007 02:07 PM
AZn8v
01-16-2007 01:24 PM
JuzPlaneKrazy
12-14-2006 12:25 AM
tywebb3
07-22-2005 11:34 PM
chrismez
14
09-20-2003 11:09 PM
