Picking up a II Silver Bullet...Questions
I think you saw another local guy from cheyenne dyno in FOCO that has a garrett stage3 with 50hp sticks and a helix2 cam and he did pretty well and spool up isnt that bad with his but he also has the "stage 2 mod" which is a
.89 E/H.
I think that if you added that flux 2's to flux 3.0's you would be fine with that turbo, the key will be getting enough fuel but smarty does fuel good which is in your favor.
What sucks is our altitude. It is the determining factor in how we build our trucks which you already know. Too much fuel can gag a truck up here and too much air can make for an interesting scenario also. But like previously state run with "OD" locked out if you have a problem then your rpm's will come up and it should reduce some surge you might experience,,,,i know that doesn't help you from a stop .....but...still.
Also run with torque management on one of the higher lvls like 3 or 4 and maybe bump rail to 2. Your tranny should be ok if your not a
I'm glad to see you going with more "air" first because as a lot of poeple on this forum would agree it is key to power with these engines a guy can never have enough air unlike fuel I just hope it spools ok for you.
You'll have to come over the hill sometime or I will
Yeah Ill let ya know how it does. I make it over the hill every now and again. And a new turbo was a must for me before more fuel. I can see dang near 1600 on my egt gauge which is something I am not comfortable with. This will be a turbo for me to grow into, which I dont mind.
yea thats why i went with the silver bullet! i dont think there is too much more room to grow unless i did twins( not going to happen). and i dont really look at the egt gauge anymore its more for show. lol
I was just going to say.. Drop it out of OD by hitting the magic button on the end of the shifter to get the RPMs up a little.. Even my Silver62 is laggy compared to stock.. I am going to try and add a cam to see how that helps and then plan on small sticks.. something in the 1.8-2.0 range..
get the fuel and save the money on the cam and the install cost
yea i remember when i got mine... it sat on the bench for about 1 month because my steering took a poop on me and had to save money for a month to get it running again. that was the longest month ever! lol when does it go on?
true i lost alot when i stuck in my 200s but you need to have some fuel even if its 90s to help fire it off.
tatkins85
17
04-30-2008 04:19 PM
texhand
02-09-2008 07:56 AM
03qclb5spd
16
01-23-2007 07:36 PM
Rollincoal
04-14-2006 11:22 AM
