piaa 510's in place of factory fogs
is the factory fog circuit (which utilizes a relay) sufficient to power piaa 510's. I did a search and found that some who wire piaa's through factory fog circuit utilize piaa supplied relay. As I mentioned, factory circuit utilizes a relay, wouldn't that be sufficient?
I wired up 4 piaa 510s and 4 piaa 520s total of eight through my factory fog lamp WIRES, but that was just for the switch. I had used the required relays to go with them after I tried to use the factory unit to run the 520's. Now as far as the 510, the may work using factory, but I know the 520s don't. lol.
Josh1979
01-07-2012 01:48 PM
grapplerusa
09-15-2011 09:18 PM
LanceK
03-18-2009 05:10 PM
pwirch
02-09-2007 07:34 AM
