PacBrake Compressor Failure
Has this happened to anyone? I am looking at getting one but have concerns about the compressor mounting location (side of the head next to the valve cover). The reason I ask is that the head mechanic at the fire department I work at said that he helped a guy out that was on the side of the road with a compressor that fails to work after awhile. He said it works fine for the first 2 hours in the morning and then quits after it gets hot. Does this location cause the compressor to get hot and quit? Does anyone know what brand of compressor PacBrake uses? Thanks for your replys in advanced.
In the begining we were telling people to mount the compressor intake filter on the fire wall. During the summer months the added heat would hit the thermal cut out. When we started telling people to relocate the intake to the front of the vehicle it quit hitting the themal cut out. Even if the compressor quits working the engine runs normal so why the fellow would have needed help from someone is unclear to me.
Harold,
Do you have documentation you can send me showing how/where to relocate the intake filter? I just may relocate mine seeing it gets hotter than you-know-where down here during summer.
Thanks!
Thanks Paul,
I called Pacbrake after posted this and asked them and I was told it is the Viair 275 model. Looks like a pretty decent compressor. I had been looking at just putting an air compressor system on the truck to fill tires and what not and I had decided on a Viair product. I hope that this kit will be ok for that occasional use (filling tires), though it sound like it is a little too small for that job.
You might as well post the info here Harold so that others can make the change.
I haven't had much luck with mine for anything other than blowing some dust off my shoes one time. It may be good for like filling an inflatable pool toy, but anything big would take forever.
The best thing to do is add a larger tank. I think Harold said up to 2.5 gal tank is okay to use with the smaller compressor. They also have larger tank and compressor options for more rigorous work.
I might end up just upgrading the tank at some point to the 2.5 gallon. I was mainly thinking of refilling tires after airing down when 4-wheeling. If the larger tanks does not help enough I will upgrade the compressor.
Ok 2.5 gal is the MAX you want for that style compressor, we do have larger 100% duty cycle units if needed with a 5 gal tank.
As for photos of the relocation unfortunately I don't have any, but if you re-route the intake around the intercooler& rad you can hang it just below the front bumper out of sight it will draw in cooler air fron there. another good place is to put it in your air cleaner box
IPDiesel
07-29-2015 09:57 PM
mrcowboy65
06-05-2013 02:05 PM
dodgetrucker75
03-17-2011 09:15 PM
icfistall
02-04-2011 10:28 AM
