P2609
P2609
Installed my Banks High Ram the other day and everything is running fine. However, today the P2609 (Air heater intake system performance) Code came on. The only difference I have noticed and I'm not sure even sure if it relates to this due to my Quadzilla box setting off a P0148 codem is that the turbo sounds like its overboosting at around 25-30 (high pitched) also when I come to a stop, the motor makes more noise while slowing down (rattling).......Anybody have any idea of what I should do to manage these problems? Thanks!
I screwed around with my TST and put it on 6&6 with an otherwise stock automatic truck. Got a suffering tranny now and have noticed a high pitch whine that I think is coming from the turbo also. I already have plans to fix tranny. The main deal is where is that high pitch sound coming from? Is it the turbo or is it something in the pump in the tranny? The reason I am thinking possible pump noise is the filter in the tranny is probably clogged with clutch material if that aint it a bearing in the converter may be hurt because the noise goes away after lockup.
Yeah, its already been determined that the Quad is going to have to come out of the truck and be returned, im on the second box with the same problem! Anyway, thats not too big of a deal. What im concerned about is the P2609 code, why is it going off and how do i, or what do i do to get rid of it?
carwash
01-25-2008 08:49 AM
