p2509 code today
Old 01-05-2008 | 09:24 PM
mudder500's Avatar
p2509 code today
i was takeing the smarty off the truck this afternoon and as soon as i got done and cranked the truck after i unhooked everything it threw the 2509 code for low input circuit error. i erased it and it hasnt come back on.
Do yall think it is cause of me taking the smarty off the truck. Or should i take the truck in to the dealer before i go on vaction?
Old 01-05-2008 | 09:27 PM
vzdude's Avatar
DTR's 'Go to Guy'
Nah......no biggie. Powerdown Data Lost - still runs? Drive it, it'll go away.
Old 01-06-2008 | 02:27 AM
DaveB.inVa's Avatar
I wouldn't worry. Take the Smarty with you if you'd like to clear codes and give you a power fix!
When I put my Smarty on first time I didn't like the smoke at all so I took it off within a few miles. Mine threw a VIN not in ECM code and died after a couple seconds. It fired right back up but kept the check engine light on. I cleared it with Smarty and have had no problems since. I have since switched programs to clear smoke and am running the mileage tune. I'm really happy with it. The only code I've seen since has been P0513 which is the truck didn't recognize the skim key. That can happen any time from what I've been told.
I have found that most every time the codes you get when loading and unloading the Smarty (or any downloader I guess) are the same codes Dodge will get when flashing your truck too. You're supposedly going through the same flash process so it makes sense to me.
Also your CAN-AM sounds pretty sweet, especially with nitrous!
Old 01-06-2008 | 12:20 PM
mudder500's Avatar
thanks for the replies guys. my thats what i was thinking when it drove fine after i cleared the codes. Now i got to take it to the dealer since my injectors are rattling like crazy stock now.
Yea the can-am is my mud bog bike. I havent got the nitrous installed on it yet but it will fly without it.
Old 01-11-2008 | 10:06 AM
svanni's Avatar
I just threw a P2509
Drove to some bagel shop, no problem. Shut it down.
Started back up to leave, and it just died driving thru the parking lot. Put it in Neutral while still rolling and started it back up. 30 seconds later it died again. Edge J/A showed a "P2509".
Haven't done any mods in a while. Any ideas ??? Thanks.
Old 01-11-2008 | 01:09 PM
judge88's Avatar
check your battery terminals. it will throw that code if there loose or not making a good connection
Old 01-11-2008 | 10:12 PM
mudder500's Avatar
well mine hasnt came back on. i put the smarty back on the truck and no codes. i belive it only did it since it was being taken off
ROOSTER108BM
05-27-2007 11:39 AM
Nuttymopar
04-26-2005 08:16 AM
kertoncol
01-19-2004 10:18 AM
Quick Reply: p2509 code today
