P0336 Code w/ Smarty TST Bypassed
I know you guys will help me out. Put the smarty on last week and decided to by-pass the TST and left my EZ on 2. Now every time I get on the WOT the engine hiccups and sets the 0336 code. You can clear it, and get on it 1 min. later and set it again. It seems to happen pretty high in the rpms, maybe 3k or higher. Think it might be TST harness crank plug in, as the TST set this code pretty often as well. Talked with another guy other day w/ only a smarty and his truck did the same thing when he first installed. Any help would be great.
Hmmm. Does it do it between 3200-3500 rpms?
I'm thinking the TST module is the cause. I would try removing the TST all together and try to reproduce the symptom.
MikeyB
MikeyB
MikeyM
08-05-2012 04:10 PM
cquestad
11-01-2004 11:51 AM
Gypsyman
58
10-16-2004 05:19 PM
cummins24
08-03-2003 06:45 PM
