Outlook Monitor for 06
So i'm getting ready to order a BD downloader and i was wonding If the outlook monitor was out for the 06 or if any one know when it will be out.
Thanks
Thanks
ya the bullydog outlook is out. I got it. MAKE SURE you get the right one from the beginning. I ordered mine & told the place the part number is 42500 combo kit & they sent me a 40500 combo kit & the harness is different for the 06 since there is no Data Link Plug & it turned into a nightmare. When you turn your truck on if I remember right it should say 3.2 on the monitor.
They are the same part number 42500. You must specify that it is a 2006. Outlook has to be version 3.2.2 It comes witht all the same wiring harnesses as the older ones, you just don't use them. You wire the yellow wire to fuse 28 and plug the OBD3 pluf in and you are set. Drill and tap your pyro and run that wire and you are golden on the Outlook.
For the Triple Dog, make sure you plug it into the Computer first register it and get the latest upgrades for it then plug it in with the key off and follow the directions on the screen... It has to be the easiest set-up w/ gauges to install to date.
Jcade@somethingustom.com if you have anymore questions...
Bradleysram
02-03-2005 01:13 AM
BUZZB8Z
01-24-2005 05:54 PM
anestech*
26
11-15-2004 01:02 PM
anestech*
11-07-2004 12:18 PM
quantrill88
10-04-2004 11:36 AM
