Ordered Tranny line with port, anything else needed?
Ok guys, I just went ahead and ordered the replacement line so I could get my tranny gauge working. Couple questions:
1. Do I need any other adapters at all? Does the line just have a threaded hole for the sender to screw into?
2. How much fluid am I looking at losing when pulling the old line off?
any other pointers would be appreciated.
thanks
thanks
I am assuming you are talking about the Mass Diesel line. If you are then it's a direct bolt in and has the port for your temp probe. As for the ATF, you may need a quart or two to top off after the job is done.
I Stand Alone
01-26-2012 08:41 AM
LanceD
02-06-2008 05:28 AM
QWKRTNU
09-26-2006 10:22 PM
PsRumors
02-23-2006 07:10 PM
