opies lift pump which psi setting for me?
i was wondering what psi i should get for opies lift pump the 12 or the 16? does it even matter? looking for between 5 and 600 horse thanks
DTR 1st Sergeant
Lemme ask a couple of questions to help. Are you talking about his mitusa mechanical pumps? And the 12 or 16 is psi? If so, it really matters little at the HP range you are talking about. The mitusas put out a lot of fuel... a lot more than needed at 500hp so the pressure doesn't matter much... well at least at the 12-16 range talked about.
Is that what you are looking for?
yes exactly what im looking for where do i get one of those pumps? thanks
also what is good psi rating for the stock cp3? i am planning on getting a floor it stage 3 in a little while thanks again
I have Opies # if you would like it, but here is his site....http://www.opieparts.com
Jordan5687
14
06-18-2010 09:41 PM
madhat
65
05-04-2010 09:35 AM
1985cucv
11-23-2009 09:34 PM
