One Last Trip to the Shop
Here are 3.3's with a 66 As you can see it would not clear the smoke on sw #7
http://s383.photobucket.com/albums/o...nt=Indy083.flv
I'd go with the largest injectors you could. I've also heard that 6.2's drive fairly well for there size.
Try this. 3.3's and a 66 got very hot
DTR Advertiser
So far, we found the 03's and 04's can use a larger injector and continue to make power. After about a 5.1 or so, the 04.5 and up years begin to smoke and not make much more power. Although there are some exceptions and eventually we will have the ability to go larger. Some guys already run a larger injector on the 04.5 and ups, but not much more power is available until we tweak other parameters.
For the 03-04's we have tried up to a 7.5. They are obviously for a max effort engine. NO towng, etc.
The 04.5's usually work well with a 4.3 or so. With single turbos and no water, limit it to a 3.3-3.8, IMO. Some run larger and do well, but I get nervous myself. Things can get toasty and melt racing and pulling without air and water inj.
03-04's can use a 5 or 6 with little driving and towing issues with enough turbo/air. Twins in other words.
There really is no universal size, since turbos, tire size and gear ratio varies so much from truck to truck. Lets not forget altitude either.
Okay so if all I'm pulling with that truck (ie towing) is gonna be our deck boat -- what size you wanna make those injectors when you get 'em in Don? somewhere in happy-land between 5 and 6? Or do you think it is in my best interest to go no larger than the 5's we already discussed. Thanks again, all!
