Ok im ready
Cp3 ?'s
So tomorrow i plan on doin the Cp3 mod. I have read and read until im cross-eyed so i just need to clear up a few things. how much do you cut the bottom of the triangle......i remember reading where some broke the whole bottom off. is this ok or should it be avoided. what is best to use to remove the endcap. what else have you guys ran into that might hold me up.
thanks
thanks
check here......
https://www.dieseltruckresource.com/...hlight=cp3+mod
There is no exact measurement for the cut at the bottom Some guys have broke the bottom off I guess thats ok but it would worry me. I got the end cap out with an allen wrench you will deform the ID of the end cap but your drilling it out any way
when i did mine, i created a small slot just inboard of the base of the triangle on one side , then a larger slot on the oposite side a little deeper. my thinking is that it would help make it a little more progresive.
ROCKNRAM
12-03-2007 02:19 PM
Luke S
15
12-11-2002 01:33 PM
reverend-ron
16
10-31-2002 08:56 AM
