oils
Old 09-02-2011 | 02:52 PM
AH64ID's Avatar
Amsoil bumper to bumper for everything but brake fluid and coolant.
AME 15w-40 in the motor
ATF in the PS and Xcase
SVG 75w-90 in both diffs
MTG in the NV5600
Old 09-02-2011 | 03:38 PM
Fiftygrit's Avatar
I use Rotella synthetic 5-40 now, tried amsoil but too much money for me as I change oil every 8k miles. 06 model its always black.
Old 09-02-2011 | 03:58 PM
bonus's Avatar
delvac 1300 here. I was running the CJ to 5000 miles, I am taking it up to 7500.
Tranny - DIFF - Transfer Case = Amsoil.
Old 09-02-2011 | 05:43 PM
NavyDood's Avatar
Originally Posted by Lost Lake
You can spend as much as you want, but I know from my UOA reports that the 2006 with the in-cylinder EGR will soot the oil up so bad that you will want to change every 10,000 miles... By then any good dino oil out there is still performing just fine. Some folks like to have overkill oil, and that's fine if it makes you happy and lets you sleep at night. For the price of syn, I think a guy could change every 5,000 miles and get much better results using clean dino oil changing twice as often. Good dino oil can be had for $9 a gallon. Drain and change the oil every 5,000 miles and the filter every 10,000 and you'd spend less money and probably be better off.
I'm not arguing, I think synthetic oils are better, but I will argue whether changing with dino oil at half the intervals is better than running syn twice as long.
This sums it up. On my 04 without the in-cylinder egr I go 25,000 miles between oil changes using Amsoil AME 15w-40 and a Donaldson ELF7349 filter and do an analysis at the oil change only. I'm on my fifth oil change using this method.
Old 09-02-2011 | 10:53 PM
Tzakiri's Avatar
I guess you're getting your oil analyzed? If so, have you tried other oils at similar intervals?
Old 09-03-2011 | 07:05 AM
MikeyB's Avatar
Valvoline Premium Blue, every 8k-10k miles.
MikeyB
Old 09-03-2011 | 12:46 PM
Snoxracer's Avatar
CENPECOin the motor,
Amsoil everywhere else! Being that I use my truck for a little pulling and it is much more fueled then a daily driver, I change my oil very often, sometimes less than 800 miles, depending how many pulls, abuse etc. That way I am getting the contaminants out.
Old 09-06-2011 | 10:28 AM
bibbo's Avatar
lots of great info guys! thanks! got alot to consider now before her first oil change
Old 09-06-2011 | 04:25 PM
poor boy's Avatar
Originally Posted by Al Ex
Redline in everything. I've done the research and it's the best if you're going to spend the $s for a synthetic. I also use (and recommend) their diesel catalyst fuel additive... that stuff has done wonders for bringing my injectors back to good operating order. Just my 2cents.
I agree on the fuel additive!!
Old 09-06-2011 | 04:27 PM
poor boy's Avatar
Originally Posted by mmurray
There is a reason it has the "C" stamped on it. Great Oil and Best Price!
This is what my local cummins shop sold me on!!!
Old 09-12-2011 | 09:03 PM
PMK's Avatar
PMK
I run amsoil with a bypass filter and went 80,000 miles last oil change. And I do have it analyzed, and it always comes back good for continued use.
Old 09-13-2011 | 04:57 PM
NavyDood's Avatar
How often are you analyzing it though? Weigh in the analyzing costs bypass set up and bypass filter costs it could take quite a few years to recoup the difference in price.
A 03-04 should easily go 25,000 miles on one filter and no bypass using Amsoil AME 15w-40 and a Amsoil EaO80 or Donaldson ELF7349 filter. My soot the last five oil changes has always been less than .1% without running a bypass.
Old 09-13-2011 | 06:01 PM
PMK's Avatar
PMK
Its not even close in cost
I started having it anlizied every 5K then went to 10. The normal filter on the bypass lasts 50K the secondary filter lasts 100K. So when you do the math its not only cheaper but I dont spend any time fooling with it, but can go fishing and hunting and all the things I enjoy without having to worry about the truck. By the way when I started having it anilized it was $12 plus postage not its more but not that much. Now its $32 but thats still way cheaper than an oil change even using junk oil.
Old 09-13-2011 | 08:28 PM
Thundercraft's Avatar
Yes, it's called licensing (read $$ )
You think that Cummins has their logo on their because they think this is the best oil for their engines, or... it meets (not necessarily exceeds) the requirements that Cummins wants and there's a bit of $$ exchanging hands?
The oil filler cap on my son's bmw says castrol oil recommended.... sad thing though is the castrol over here ain't what's offered in the fatherland.....
Licensing is Huge money.
Am I saying that you shouldn't use that oil or that it is a lousy product? No, not at all.... just don't mistake an endorsement as meaning it is the best product to use - it's just best for their respective bank accounts.
If Cummins had taken it a step further (like many of the motorcycle companies) and put their own label onto the jug (or any brand of oil for that matter)... they would still recommend that your Cummins runs best with Cummins liquid gold......
Old 09-30-2011 | 10:23 AM
csramsey640's Avatar
A few years ago Ford put that the recommend BP gasoline right on the gas cap of every gasser vehicle. I actually had people run out of gas looking for a BP station
FWIW, I run Synthetic in my diffs, and a mixture of Pennzoil Synchromesh and Lucas Synthetic Additive in the tranny. Just regular ATf +4 in the transfer but will change to Synthetic soon.
I just switched over to Rotella Synthetic in the engine, but since I have researched this in cylinder egr, I will prob go back to dino and 7,000 mile changes.
Quick Reply: oils
