Oil Pressure Port
yep. had mine there originally, then moved to the lube oil gallery on the engine left side [there are 2 m10x1.0 ports there] the ports on top of the filter pad are standard 1/8" npt fittings
the reading is about 2-3psi lower off the block side... i plan on running a lube oil temp gauge and the filter pad is a better location for temprature. the one port is easy to access, the other is blocked making it a poor location to get pressure or temp off of.
jrs_dodge_diesel
06-23-2010 10:43 AM
GlennRMK
05-24-2007 10:46 PM
QWKRTNU
09-26-2006 10:22 PM
rjm022
02-07-2006 01:23 PM
