Oil Pressure Gage
Oil Pressure Gage
I have an open pod in one of my gage clusters. i have read about the value of knowing you have good oil pressure in the pan (cracked injectors leaking fuel in and so on) Is this a valid case? Does anyoen here run one ? If so where did you put the feed line for the gage and where did you get the gage. I run Dipricol gages now and would like to match the appearence.
Hi, I have a one in a overhead mount. I put the sender in the oil fliter housing, there are 2 1/8npt plugs on top, I used the one to the left as you are looking at it. I had to get a 45deg pice of pipe fron the hardware store to make it work, there is a collent pipe right above the housing that prevents you from just putting the sender in. My pressure is about 35-45psi cold idle, 13-18psi hot idle and about 45-50psi at anything above 1000rpm, also I'm running Shell Rottela T 5w-40 synthic. I got the gauages from Jeg's they are Autometer
Location: Smith Valley, NV (sometimes Redwood City, CA)
[QUOTE=genros;1487087]I have an open pod in one of my gage clusters. i have read about the value of knowing you have good oil pressure in the pan (cracked injectors leaking fuel in and so on)
What do you mean by oil pressure in the pan?
Wetspirit
Wetspirit
pan pressure?
[QUOTE=Wetspirit;1487968]yeah, i was wondering about that too, but was afraid to ask Thanks for doing it for me!
retiredguy
18
10-01-2011 05:23 PM
