Oasis differential covers
Have any of you guys bought these and put them on your rig? I am thinking of getting the polished differential cover front and back, but wanted some feedback on them and why you chose them over Mag-Hytec, Dynatrac, etc.
I have an Oasis. I chose it because it was almost $100 cheaper that the others. I think the mag-hytek has a level gage, but I don't really need that so the oasis is perfect for me.
- Adam
- Adam
I have had an Oasis cover on mine for 4 years. They are awesome. The only thing I did was get longer allen head bolts. I am pretty sure this is not an issue anymore with them, just make sure you use a thread locker!
Ditto!!!
Same here. Plus Lower cost than Mag-Hytek. I was kind **** and lined up the Oasis cover with the stocker using dowels and found the fill port was dead on with the stock fill port so the fluid level (1/4" below fill port IIRC, a small allen wrench can be used to check) was same as with stocker.
jesussaves
01-03-2011 12:43 PM
rodsram
01-13-2008 03:52 PM
ColoradoSprings
06-09-2007 08:34 PM
