O-ringed Head-What Gasket
Old 09-11-2007 | 08:26 PM
wallawalla's Avatar
Question O-ringed Head-What Gasket
I just bought a ported head that has been o-ringed, and the guy that had it said that he just used his stock gasket, but i though i read somewhere here that you could not use a 3rd gen gasket with an o-ringed head and that you had to use a 2nd gen one. Basically i need to know the best head gasket i can use(marine, cometic, or stock) and what generation it needs to be.
Thanks for your help
Old 09-11-2007 | 08:35 PM
bnold's Avatar
dunno on 3rd gens but I'm using a slightly modified marine gasket on mine
Old 09-12-2007 | 11:39 AM
cranked_dodge's Avatar
You need to use a 24 Valve head gasket from Cummins part number for that item is 3977063 that is the part number I have from cummins and I used that gasket in my truck and also one of my customers trucks ans have had no problems.
hope this helps
Old 09-12-2007 | 12:31 PM
Timinva's Avatar
DTR Advertiser
I used a stock thickness marine 12v gasket on several cr o ringed heads. You need to add a little rtv on drivers front of it. Been several thousand miles no issues so far. Tim
diezel freak
10-28-2009 07:56 PM
ScottGregory
01-26-2008 11:27 PM
caleb c.
28
03-02-2007 11:26 AM
txdodge97
03-01-2007 10:51 PM
storx
44
09-30-2005 04:36 PM
