O-ring And Head Studs
#31
O-ringed vs. Fire-ringed
Sorry, I do not mean to hi-jack your thread. I just need a little help understanding the difference between the two (o-ring & fire-ring.) What are the differences in the machining process? Are different gaskets used? What are the capabilities of each one(how much boost?) What exactly is the difference between the 3rd gen head and the others?
Thanks
Thanks
#35
Originally Posted by greyrig05
im not sure but, i heard you lose compression when you fire ring a new commonrail with the multilayer head gasket. is this true?
Geeeze, Who told you that?? Sounds like something a mudflap expert would say!!!
If you wanna fire ring a new common rail all you have to do is cutout a couple of coolant passages from an older gasket and remove the inner cylinder ring from the gasket to allow the fire rings to seat down in the grooves you machine in the head.
Fire rings take up all the force and heat from the combustion chamber thus eliminating all the stress on the gasket itself. This is why it's a good idea to do on trucks that wanna run high boost, drive pressure's, ect.... and do it on a regular basis without having to worry about having their truck down if they blow the gasket.
Cheers
#36
Cheers
Cheers
how does it feel knowing that your only running 13s and your not the record holder at bandamere
#38
Originally Posted by acook
Im sure he feels fine since you wernt the one beating him LOL
well allen, i know and he probably knows that fuel for fuel id wear him out. seems here lately you been following my post. get used to following. soon as you get your tranny in thats what you'll be doing.
#40
But you have to have a truck that runs first
pwrtripls1
03-10-2011 01:12 PM
smokewagon
08-08-2008 10:54 PM
CTD_Neil
13
02-08-2007 04:29 PM
SmokenRam
13
02-19-2006 07:35 PM
