O-ring And Head Studs
Old 07-31-2006 | 02:51 PM
goodeyesniper75's Avatar
Does Anyone Know Of Someone In Nj That Does O-ringing And Somewhere That I Could Get Headstuds For A Good Price
Old 07-31-2006 | 02:58 PM
HappyGA's Avatar
well, it will take a day or two to get the head done, so why not order the head studs from ARP through the net or either by calling them???
Old 07-31-2006 | 03:28 PM
Where Do I Get The Heads O-ringed?
Old 07-31-2006 | 03:44 PM
HappyGA's Avatar
I think i have seen a lot of people on here say they had Scheids do them, but Ai qam not sure how far you are away from them. how far are you willing to drive to get it done?
That would give the guys and gals here more info on where they can recommend a good machinest for the job. The main thing you are gonna want is someone who has done it before and does a lot of them if possible.
Luken's Avatar
I've heard you can get a good deal on ARP's from Source Automotive. That's what I plan to do.
Old 07-31-2006 | 03:46 PM
I Am In Nj And Would Drive A Ways If I Had To. Another ? Is Arp Or Ats Studs..AND HOW HARD IS IT TO DO CAN I DO IT?
Old 07-31-2006 | 04:12 PM
HappyGA's Avatar
well, you have to remove the heqad of course, and it will require an engine hoist, and be a little tricky with the tightness and maneuvarability. I would say two days one to take it apart and one to put it back together. But that would be for me, and on a scale of 1-10 I would give myself an 8, cause there are some things I don't know, but can do most anything i want to.
I reccommend ARP's cause they have been around for a long time, and have proven themselves in the performance market time and time again.
I am sure someone will chime in from the Yankee states with who might be close to you that has done the oring grooving.
Old 07-31-2006 | 05:58 PM
stang's Avatar
Fonse Performance and Marine give them a call there full mech. shop 856-627-5946 no real trick to O-ring just have to have the right tool and they are an ARP dealer
Old 07-31-2006 | 06:18 PM
Don M's Avatar
DTR Advertiser
I would not o-ring the MLS gasket flange. Just MHO.
Don~
Old 07-31-2006 | 06:22 PM
acook's Avatar
Don~
Just curious, why not?
Old 07-31-2006 | 07:17 PM
Luken's Avatar
Don~
This is the info I need to hear. Im getting ready to tear into mine. Some say just put studs on and some say o-ring it too
Don,
Clear your pms I need to ask you some ?'s about injectors for my truck.
Thanks
Old 07-31-2006 | 07:20 PM
acook's Avatar
thats what i want to know, ive heard some people i belive are very credible say that you need both or itll blow, and some say just studs, so which is it?
Old 07-31-2006 | 07:24 PM
signature600's Avatar
The MLS gaskets on the CR trucks have been holing 65+psi with twins...with only studs, no orings! For most people, that is plenty
The only thing you have to do, as far as I know, is make sure the head and deck are FLAT!!
Chris
Old 07-31-2006 | 08:05 PM
genros's Avatar
through a load of research I have learned that o-ringing is not needed til your up around taht 65 lbs mark. If you need a good shop not sure if your near pa but there are a couple of shops over here near phila and also one or two I know of in south NJ
Old 07-31-2006 | 08:12 PM
getblown5.9's Avatar
ive heard info (not rumors) of some testing with a truck still hodling 75psi on the stock headbolts and MLS gasket...but to be safe, a set of ARP head studs will be enough to about 70-80psi...
again i really wish someone made an MLS gasket for my 2nd gen
