Nozzles or full sticks
Lookin 4 the next level in HP mods
Do most run modified full injectors or just change the nozzles . pro's & cons on either choices? all I know is double in coin !!!
And with the choices of higher HP sticks is it determined by larger ID on the orifices & multiples of . The reason I ask is most vendors ask 4 core charges which I believe they modify the stock using wire EDM purposes . I ask this because I've never held a stock injector let alone a higher HP unit & my job duties require me to use wire EDM machine my min. wire size @ .003 of an in.
You're feed greatly appreciated
Thanx Len
Thanx Len
The way I understand it all 3rd gen cr injector bodies are identical. The only difference is the nozzles. However I won't touch edm versus etrude honed You could replace the nozzles/tips yourself. Best thing is send in your complete injector to F1 for a complete going over, hope this helps.
DTR 1st Sergeant
It is the nozzles that get changed-- not the whole injector... unless you have something else wrong with it. It is wise, if you are not certain of the condition of your injector bodies, to ship them out and have nozzles changed and the bodies gone through and flow tested.
FWIW... You need more turbo before you need new stix. No question about that.
Personally Id want to go w/ Don M's stix, but I cant afford to have my truck down for a couple of days. Im looking at Wicked diesels stix no core charge.
redlineguy
15
01-09-2012 09:15 PM
13bdarren
01-27-2009 12:39 PM
West Coast
07-04-2007 10:25 AM
j
11-14-2003 09:38 PM
