Now thats more like it!!!
Old 01-20-2005 | 05:47 PM
B Proctor's Avatar
Thumbs up Now thats more like it!!!
Just installed bully dog pup downloader software on my '05 CTD and WOW! I'm currently on performance mode and loving it. This also cures the OD/TOW mode lockout on my truck. Now I can push the tow button and it'll drop down into Drive like the 4.5's. Good work Bullydog! No codes, engine lites, or any other irregularities. Runs like a dream on the interstate, now I've got to get busy on air, exhaust, and gauges.
Old 01-20-2005 | 09:13 PM
John Rodriguez's Avatar
Tire Hater
With the stock tires, removed cat, and mods, I put down 400whp on Extreme.
Old 01-21-2005 | 01:04 AM
Kyle Graham's Avatar
Excellent I have a bunch on order hopefully they will be here soon. I receive some but they were already sold maybe this time I will get to have one left over to play with
Old 01-21-2005 | 10:29 AM
B Proctor's Avatar
Yeah I liked the vid that John_R put up, saw he was using the pup to make all that smoke. Did a lot of reading and decided to try it myself. Truthfully the results are better than I imagined they would be. Mileage is up from 17 to 19 mpg, truck is a lot more responsive, and the transmission tow button now locks out OD like a '04. I can get the RPM's up more during normal driving. After flashing the truck it drve a little strange at first, I guess while it learned itself, but after a few miles it setteled in and performed very well. 100 miles later and no engine lights or thrown codes. Simple straightforward installation, no hidden surprises, I am a satisfied customer with this product.
Old 01-21-2005 | 11:31 AM
nonford's Avatar
I was thinking of getting one too. Did the problems with the SKIM, TSB's performed and the like get corrected with these units? Thanks in advance.
Old 01-21-2005 | 12:24 PM
Nascarcamper's Avatar
Re: Now thats more like it!!!
You better hurry on the gauges part, it may take your breath away when you see what it is doing. Just my .02 worth.
Old 01-21-2005 | 12:49 PM
B Proctor's Avatar
Copy That ,
I had gauges ordered for delevery today (Fri), but supplier unable to ship out in time. Be installing them first of next week.
Old 01-22-2005 | 12:08 AM
Tire Hater
I don't know if perhaps my gauge is a bit slow, but a WOT run with 4hi launch and my egts never go over 1250. On the dyno using 30% brakes from start to finish, my egts didn't go over 1400 pre-turbo.
Old 01-22-2005 | 09:18 AM
BPD239's Avatar
John_Rodriquez
Is there something different about the 05 compared to the 4.5 with egt's. I'm interested in hearing what your egt's were before you used the downloader. I am on the fence now with a box or a downloader. I need something that will not run too hot. I can EASILY hit 1250 driving empty on the highway. I see 1250 getting on the highway. That is with the airbox drilled out, and the muffler removed. I saw no reduction when I took off the muffler.
Old 01-23-2005 | 02:58 PM
BullyDog's programming has been known to increase power and Keep egts down
Old 01-23-2005 | 04:14 PM
Tire Hater
BPD239, with stock programming and 35" tires, it hits about 1,000 getting on the highway. I really don't pay attention to egt's unless it's time to shut down the engine, or I see it over halfway on the gauge.
Old 02-10-2005 | 11:05 PM
bluepp's Avatar
bump
Old 02-10-2005 | 11:57 PM
Raspy's Avatar
Does the Bully Dog increase fuel pressure or increase injection duration to get more power? I'm worried about increased rail pressure leading to problems.
Wetspirit
Old 02-11-2005 | 12:07 AM
AK RAM's Avatar
Originally posted by BPD239
John_Rodriquez
Sounds like someone is in need of a turbo upgrade. Check my classified ads.
Old 02-11-2005 | 01:18 AM
RadRam's Avatar
wetspirit - My outlook monitor - shows a max rail pressure of 24000 psi with the pup on 130 stacked with a stage 1 predator. normal 60 mph 17000 psi. Everthing else on the outlook reads the same as my other gauges, so it looks accurate.
checkster
02-17-2009 11:53 AM
Old Hat
12-21-2008 11:06 PM
dieselfuelonly
10-28-2008 02:21 PM
Cummins66
04-14-2004 06:21 PM
FMF MX
12-03-2003 12:30 PM
