Non-posi truck definetly came with a posi.
Non-posi truck definetly came with a posi - correction=not posi.
Today I did a posi test (again). With the tow mirrors out so I can watch each tire. I backed up to some dirt, dumped the clutch in granny-gear, then kept the RPM's up while keeping my left foot on the brake pedal. Both tires just kept going forward at the same speed and digging two identical sized holes in the dirt. The other posi I bought for my other truck and then pulled out before I traded it in will hit e-bay.
Before getting rid of it I would check the inside of the rear differential. If after removing the cover you see a large flat gear to the side of the ring & pinion you have the Dodge style of positraction. If no gear no posi....Think I'd check to be sure before getting rid of it.
JMHO
JMHO
JMHO
JMHO
On the other hand if you really do have a posi in a non-posi truck, rock on!
I want to buy a cooling cover for it, but now I really want to go take a look. I have seen them both. I will probably go see what I can see through the drain plug on the cover. The open carrier it seems will be easy to identify, 2 sides, spiders and a shaft. The gear posi is mostly enclosed with only little windows to see the internals. It has to be one though. My last truck, with an open, never hit both tires. This test today and the two long ruts in the sand last week, identical with me watching both tires spin the same way seems very convincing.
Well, I went and looked in the drain plug and it is an open carrier. Wide open with big ole' spiders & shaft for me to see. Dang. When I got complete dual traction in the sand & dirt, I thought for sure it was a posi. No other open diff. I have ever had did this. Oh well. I am still swapping it out for the posi one. Thanx guys.
Did your sticker say "anti-spin" differential? Mine does, and in researching this and another board that means it has the Dodge type "limited" slip. I have not had my cover off yet, to look inside, but both wheels turned opposite in the air. I always thought this meant open diff. Apparently not per the research.
With these gear posi's there needs to be some resistance I believe. I am still bewildered why my open diff. acts like stiff osi in sand & dirt.
jmccart
07-07-2007 12:46 PM
chuck gibson
06-07-2006 08:07 PM
Gambino-01
04-08-2006 01:36 PM
PROSOUTH
22
07-11-2005 08:13 PM
