Nitrous bottle location??
Old 08-14-2008 | 06:47 PM
matego's Avatar
madhat's monkey boy...
Where are you guys mounting your N2O bottles? I have a 10LB bottle and hate to mount it in the bed but that thing is a lot bigger than I thought. I cant figure out any good way to mount it under the back seat and I am concerned with a possible leak gassing me out. (remember Black Sheep ) Any ideas? If I mount it in the bed do they make a cover for it or do I need to fab something up?
Old 08-14-2008 | 06:50 PM
cbrahs's Avatar
there is a guy up north that has a Dmax and he has his bottle mounted on the left rear corner of the bed inside a gym bag. so when the tailgate is off the gym bag is zipped up and you can't see any hoses at all! looks pretty stealthy IMO. you can't even see any of his gauges. sleeper truck and it is pretty fast.
Old 08-14-2008 | 07:01 PM
XLR8R's Avatar
I just put mine in the bed, but there's a good spot where the muffler used to be if your 304SS water/meth tank isn't there.
Old 08-14-2008 | 08:20 PM
matego's Avatar
Lmills wants me to mount the tank in the front hole of my RA bumper where the winch goes. It would look pretty cool but I fear a collision would rupture the tank. I guess I will just mount it between the stacks on the back of the bed and try to make a diamond plate cover for it and somewhat seal it up from the elements. A remote bottle opener will be next on the list.
Old 08-15-2008 | 10:18 AM
XLR8R's Avatar
I need one of those on the cooler!
Old 08-15-2008 | 11:46 AM
lmills's Avatar
OMG, that was a joke and would not recommend it for daily driving either. LOL You are too nice of a guy for me to want to see injured if it would explode in a front end collision. Competition use and trying to hide it, maybe.... Of course I would never condone hiding something like that. LOL
In the bed between the stacks in a box I would be worried about heat causing the bottle to have extreme pressure from the heat of the stacks. I know when I have mine under the toneau cover the temps get warm enough to bring the pressure up to the limit of the gauge at 1500 PSI.
Old 08-15-2008 | 12:11 PM
banshee's Avatar
I run mine on the floor in the center of the back seat. It's easy to turn on and even on a hot day the pressures don't get too terribly high. I did have the bottle relieve itself through the safety burst disc one time when I accidentally flipped the heater switch on with the valve closed. If you vent the safety relief outlet with a blowdown tube there really shouldn't be an issue with it. I run the hose and heater wiring forward under the center seat, center shifter and then up through the dash. I have a pic of it I can post up later.
Old 08-15-2008 | 12:52 PM
matego's Avatar
I knew you were just playin' It would be real dumb for me to put it there. I really dont care about hiding it either except for some punk cutting my tank off when I am parked somewhere. I was thinking of between the stacks mounted on the front of the bed. It really does not get that hot but I may just be trying to convince myself it will be OK.
I would really like to do the same but my kids are with me 90% of the time and everything has to be touched or messed with. It may just get mounted under the bed where the muffler was like XLR8R said. I dont know what I am going to do but I will post up pics when I get it done.
Old 08-15-2008 | 12:58 PM
jaredb900rr's Avatar
If you were to put it on the floor in the center of the back seat area, like banshee, could you take it in/out easily for when you do have passengers, or aren't using it? Are the lines okay being disconnected if you secured them out of the way?
Old 08-15-2008 | 01:03 PM
XLR8R's Avatar
... you could vent the purge line to cabin air, and be like all the way through the big-end lights!
Old 08-15-2008 | 01:06 PM
Steve: [high on nitrous oxide and looking at a map] Roges? Rudes? How come I can't say that word?
Mike: Roads!
Steve: Rowads! That's a weird word, isn't it?
Old 08-15-2008 | 01:42 PM
matego's Avatar
Mike: Roads!
http://www.moviewavs.com/0038475992/...roadsroads.mp3
Good times!
http://www.moviewavs.com/0038475992/...tbackthere.mp3
Old 08-15-2008 | 05:50 PM
RunninLean's Avatar
I bought a small diamond plate tool box that sits in the bed below the rails. I drilled a hole in the bottom to line up with the bed drain closest to the cab on the drivers side. Installing heater and remote opener this weekend leaving the heater swith in the tool box also.
Old 08-15-2008 | 05:58 PM
banshee's Avatar
You can remove the bottle, cap the line, and put a plug on the heater/pressure transducer, but the bottle brackets will still be there. Unless you could find a fancy bracket setup they're a pain when they're loose.
The sulfur dioxide in the nitrous will give you a headache long before you'll get giddy with it...
Old 08-15-2008 | 08:00 PM
chrleb1's Avatar
In the middle seat, tied into a car seat.
Most people go into the bed. My friend did the gym bag trick also. It looked pretty real. NOS does make a full blanket for it if you'd like. If you put it in the cab, you have to have a blow down tube off the safety valve. The blow down tube has to exit the cab also (hole in the floor). Now these are track rules. Your rules for whatever, is whatever.
