New transmission
My tranny went south on tuesday. A full billet unit, first one that they have had let go like this,, they (NADP) are building another unit for me,, excellent service. Just too bad it had to be me that got the excellent service. But I guess things happen from time to time
Kevin
Kevin
and another DTT by James Northum in the works......
Tow haul works properly.
i got a buddy with a dmax and he has with through 3 ATS trannys, 2 level 5's and 1 level 7, and the 7 was slipping with just his motor work, aurora 5000 and 200hp injectors, he didnt even have his triple stack and water/meth on it
he's just going to drive out to denver next week to get it fixed, long drive, but i would be ****** too if i've spend 16K in trannys
Billet and whatever?
I don't care what tranny company you use, DTT, ATS, HTS, or whoever, and you billet everything, no-one that I know makes a stock replacement clutches that can hold up? The only up-grade the 47re clutches are the 48re OEM. I need kevlar or some other material that hold hold up to the heat. So what I'm saying is, right now there is no bullet proof tranny for 3rd. gens as the weak link now is the clutch packs...
Whose tranny do you have. I have seen a few "built trannys" and one of the big companies had stock clutchs in it...
Mine dosent have stock clutches either,, they use a special aftermarket brand,, and then use lots of pressure to make sure that they dont slip
Kevin
Kevin
Dauntless
15
08-30-2016 08:37 PM
Derek Crowl
08-20-2013 10:43 PM
roho123
06-05-2005 02:51 PM
admin
14
10-23-2002 06:48 PM
