New Smarty Revo TNT
#61
every truck is different you might have a weak cp3 or a strong cp3 or someother component that makes yours fuel harder spool quicker it all depends everything is different its trial and error
#62
Well, after trying all the TNT levels on my S06 POD, the only level it surges is on TNT#9. All the other Catcher #'s don't surge at all but don't have the smooth, quick throttle response that TNT #9 has?? What do ya guys think?
#64
#66
#67
X2 i like the 4.4 and the 4.3 but i really love 4.2 then with the mp-8 stacked on it is even more fun. i don't think i have ran the 4.4 or 4.3 with the mp-8???? may like it more. not sure what so you think.
#69
The 4.2 is too much for my tastes, since I'm almost always hauling a trailer around, so I usually stick to the 4.4 with the mp8. Pretty happy with that. Might find myself going to the 4.3 soon though, can't stay with one thing to terribly long.
#72
Hey, guys! As some of you may know, I recently changed from the Edge hot juice w/attitude to Smarty Revo and an edge insight monitor. Edge lvl 6 "hot" is rated at 160 hp and 350 tq. sw9 is 170hp ?tq. sw9, tq2,tm2, rp2 should be even more that, right? The thing is that lvl 6 on the edge felt more like 10 hp more than this instead of less, so..... is there one of the betas or tnt or something that would be better? Also, do the betas work with revo software, or are they just pre-set lvls with no adjustment?
#75
Each level increases the amount of time the injector stays open (duration) this allows more fuel to enter the cylinder and makes more power. However a stock CP3 and stock lift pump are going to have a very hard time providing adequate pressure 23,000+ with that much duration and your stock turbo should be getting quite hot too. Are you running revo standard or TNT?
Some CP3's are better than others, maybe you got lucky but if you go to bigger sticks you are definately going to want to upgrade your fuel system and will probably want a turbo too. Good Luck, Tom J.
