New smarty owner,but...
I finally hid enough money from the old lady and bought me a smarty (version 4.13b TNT/REVO) and love it.My problem is boost #'s are low.When I was running my tripple dog 2.4d,TST,ramifier combo it would waste at 55lbs. Now with the smarty I can't get over 40. I've tried every possible combo on the revo with and without the ramifier and it's a wall at 40.I put the bully dog back on and 55lbs.I even tried a quad boost fooler and still only 40.Thanks
The TnT is beta, and there are a few different versions out there...i have the older version (not 5.3)....and i'm seeing the same thing...on the old non TnT beta 4.4, i'd spool to 40psi in a heart beat, TnT won't get me there w/o effort...but the power is definately there even w/o the high boost....
I wouldnt worry about it for now, Marco's refining the software and when it's released, no worries....
madhat's monkey boy...
I had to give Bob a quart of Plasma and my first born son to get the REVO
I have the 4.13b and I have no problems hitting 45 PSI boost (wastegate setting) and with the MP-8 I can actually blow through the wastegate and hit 52-54 PSI. I assume you are running #4 tq management..... right?
SW9, TQ4, timing 2, pressure 0 (default) and aftermaket turbo will make 45 PSI no problem. Are doing a full download after you change your parameters?
I'm running 4.13b, SW7, Tq 3, timing 2, pressure 3 and aftermarket turbo...
i'm reprogramming after changing options...
For me, it get's to 40 ok, just not like it used too with beta 4.4...i think its the smoothness factor....i don't really floor it all the way (could be it)....i was used to the beta 4.4 agro (you didnt need to floor it)....and tq mgmt 4 doesnt get along with my trans so i'm on 3...
And truthfully, it's just as fast if not faster than beta 4.4, very smooth, very linear throttle, not too much smoke....it just doenst spool the turbo as quick as 4.4 did on my truck....at least the way i drive....not really a problem for me.
truckroc
Introductions / New People
06-10-2017 02:57 AM
92GhostRyder
08-11-2010 08:31 AM
Mopar72
11-11-2007 07:04 PM
