New Silent Fass Pumps!
Old 01-05-2007 | 06:34 PM
  #31
tristan21's Avatar
Thanks Dan, I will get it to you soon as I get back to the paperwork in PA.
Old 01-05-2007 | 08:35 PM
  #32
Speed Shift's Avatar
Here is a new video of a HPFP 95, it doesnt get any quieter than this.... I put the camara 6" away from the pump, no zoom here....
http://cumminsforum.vidiac.com/video...ac01489477.htm
Just one spring and I will be running 45psi
Old 01-05-2007 | 09:10 PM
  #33
973604x4's Avatar
hey that parking lot looks familiar!
45psi? time for a billet fuel filter cap!
Old 01-05-2007 | 09:14 PM
  #34
At least I made it home in time to shoot this one in the daylight.
No fuel filter cap for me, I bypassed the stock element, and use a
2 micron.
Old 01-05-2007 | 09:17 PM
  #35
973604x4's Avatar
2 micron.
ohhh yes i forget you are special
Old 01-05-2007 | 09:19 PM
  #36
MoparRiggan's Avatar
Originally Posted by Diesel-Dan
This is open to pretty much any pump. Like i was saying on another forum, the 200 GPH are going to make some noise...but we can make them more tolerable. On these pumps, with or without the seal, I would recommend sending into us so we can get it as quiet as possible on the bench.
Diesel Dan, I was planning on putting the plate on myself on my 200 GPH, but you state you have a way of getting it quieter than I myself can if I send you the pump? Please explain how,
Thanks, Jason
Old 01-06-2007 | 05:31 PM
  #37
Hawkeye 04's Avatar
Dan, I've got a 95GPM pump only and want to quite the thing down, but am wanting to upgrade to something that will boost more pressure. Do I only need a spring replaced or can you work out a trade for me for a 150? Thanks
Old 01-08-2007 | 09:08 AM
  #38
Diesel-Dan's Avatar
Thanks, Jason
If you send it into us......it won’t leave here until a noticeable difference is noted....that is the advantage in sending in the pump to us. We have a db meter we use.
Hawkeye 04,
If you have a FASS, all you need to do is get a PS-1013 spring and you have 45 PSI. BUT this will only work with the 95 GPH. They can run higher pressures.
If you have a HPFP, you will need a PS-1005 spring for 45 PSI. BUT it needs to be a 95 GPH. If you don’t have a seal, it is possible to change the spring out yourself. If you have a seal, send it in and let us know what pressure you want to run and we will make it happen.
Old 01-24-2007 | 05:54 PM
  #39
Diesel-Dan's Avatar
Here is a vid of Brads truck. We had this 95/95-1007 Pump on his truck for a while. BUT i randomly took out one of our replacement pumps we had on shelf and swapped it out on his kit. This is the vid of how it turned out.
Old 01-24-2007 | 11:09 PM
  #40
Bad Ramer Jamer's Avatar
Ohh come on. There aint no FASS on that truck.
Now that's more like it. Hopefully I'll get back in town soon and be able to take car of mine.
Where did you get the rear running board's. You happen to know if they come in red.
Old 01-25-2007 | 10:56 AM
  #41
Diesel-Dan's Avatar
UM...ill ask Brad....they are nice! Im sure Krylon has your color.......
Old 02-03-2007 | 03:22 PM
  #42
cejrunner's Avatar
Diesel-Dan, I had a HPFP installed on my truck this week Feb, 1st to be exact. The dealer had to order it so i assumed it was a new version. However, it is considerably loud. Not that that is a problem. I just was expecting it to be much quieter after reading these posts.
Old 02-05-2007 | 09:27 AM
  #43
Diesel-Dan's Avatar
SN? I can see when your pump was made.......
Old 02-05-2007 | 10:32 AM
  #44
cejrunner's Avatar
Diesel-Dan
i have mailed the warranty card in already. The S/N is 02636. Also, do you have any type of FASS decal for my rear windo for the competition to see as i blow by?
Old 02-05-2007 | 10:49 AM
  #45
Diesel-Dan's Avatar
Diesel-Dan
You kit does not have the update. As for the decal.....should have had a few in the box. If not....ill see what i can do......
