new sbc ofe problem
new sbc ofe problem
Just had the ofe installed now the tranny is hard to get into gear (1st/rewind)
from a standstill
Does anthing have to be bleed again after installation or any other answers?
from a standstill
I just had an OFE installed and a BD short shifter at the same time so it's kind of hard to distinguish what caused it but I experienced the same thing. It wasn't major but was harder to slide into the gears. It loosened up after a week or so...
Yes it grabs right at the floor, I have only put on 200 miles, mostly highway on it, so it "may" get better
If not whats the hyd upgrade worth? I thought it wasnt needed until you get dual disc
I don't have the hydraulic upgrade and I don't have that problem. I considered it but Peter at SBC said it wasn't necessary until you go to a DD. If I remember correctly the upgrade was around $175
I had the same problem when mine was first installed. Mine was so bad that SBC sent me a new clutch and the problem went away. I do not know if it was the clutch or just the actual install where something may not have been lined up/off just a bit or what. The shop that installed mine first tried a new hydraulics, but that didn't do much, but afetr they installed the new clutch it was fine, it may have been fine if the origional was just removed and replaced also, but who knows.
hotdram
14
02-18-2008 07:17 PM
hllbllyhellion
08-13-2006 08:22 AM
dodgediesel4x4
05-08-2005 08:21 PM
PaulG
11-05-2002 09:30 AM
