New projector headlights are on
Originally Posted by realsquash
What type of bulbs do these normally take and what are you using?
Thanks,
Andy
Thanks,
Andy
HOW are they adjustable? Sounds like a pain. I know the headlights in my mb just have two dials, one for right/left and one for up/down adjustment...pull up on level ground to a brick wall - baddaboombadddabing! How do these work?
PS they look pretty cool. I little ricey, but cool.
So what I did was made adjustments, pushed the headlight assy. into place and checked the alignment. If it needed more, pop it loose, turn the screws and check again. Took me maybe 15 minutes for the whole thing.
Once your satisfied, install the three mounting bolts and your done.
Originally Posted by BEHRMAN
JC-Can you tell us which seller you got these from?
Here is a link to one of their auctions.
http://cgi.ebay.com/ebaymotors/C-02-...4427QQtcZphoto
They also have them in black.
Jc9995,
Were you finally able to get them aligned well?
When you say you have to splice the halo lights into your parking lights, does that mean that you can leave them disconnected if you wanted? I don't seem to hot on the idea of trying to make my truck look like a BMW.
Finally, did the manufacturer/seller say it would be ok to run HID lamps in the low beam fixture?
Sorry for all the questions, these have peaked my interest but i'm an overly careful shopper.
Mike
Mike
Originally Posted by Bluedeviltorque
Jc9995,
Mike
Mike
I have not asked the seller about HID bulbs, but I dont see why it would be a problem. HID runs much cooler than halogen, so heat isnt an issue.
The halo lights have seperate wires coming out of the back of the fixture, so you can opt to not hook them up.
I am careful too, and even went as far as contacting previous eBay buyers of these headlights, but never did get a response, so I am more than happy to share what little knowledge I have in this puny brain of mine. (my wifes words not mine).
You can't run real HID bulbs without the appropriate ballast. You can run hid look-alikes like sylvania silverstars etc I'm guessing without a problem...
http://cgi.ebay.com/ebaymotors/JDM-P...spagenameZWD1V
Does the seller of the light kits also sell the HID/Ballast kits? If I could get the whole package from 1 source, I'd feel more comfortable with the compatibility of pieces. They do look good, wouldn't mind seeing a set with the black background.
Originally Posted by Jc9995
1. Fit and finish leave some to be desired, but is not too bad. Just larger gaps than I would have liked.
Originally Posted by Matt400
I took a look at your pics and it was hard to see what you mean. Is there a gap at the back or is that simply the black rubber gasket? If its at the bottom you are talking about its pretty easy to close up that gap buy moving the bumper higher.
