new lower HP boxes?
new lower HP boxes?
With the advances in pulse-width and timing Edge and TST are making with the new 150 HP boxes - will they use this technology to produce a new 80 hp box? Seems like it would be better on the fuel system and perform better overall versus what they have now in the lower HP boxes. I don't particulary care to run a 150hp box because I'd have to change my turbo and clutch ($$$$$$) and still couldn't tow anything on that setting. I'm not a racer but I want to tow with the highest HP setting and still retain my stock turbo.
Guest
Posts: n/a
Re:new lower HP boxes?
The box is adjustable and can be used in settings all the way up to 150 hp but it has lower settings from what I understand. I don't think major mods need to be made unless you run the highest setting most or all of the time. This is what I understand of the box that is coming soon but not soon enough.
If their is a lower 80 or 100 hp setting that would be good along with ability to program the max EGT you would allow. I e-mailed TST a few days ago asking them about the use of the 150 hp setting with stock exhaust, airbox, and turbo. This is the reply I got - intersting comments about exhaust and airboxes.
TST - "At 150 extra horsepower the egt's are extreme, thus useable only for a few seconds at a time, like street/drag racing or sled pulling. About 80 hp is the most that can be used and still have safe continuous exhaust temperatures.
There is a lot of hype in the aftermarket as we have done extensive testing on previous Rams from 89 to 02 and have not found any benefit at all (no power gains or temperature reduction) to larger air filters, different air pickup locations, or larger exhaust. We plan to do similar testing on the common rail engine but based on previous experience, have very little confidence in these alterations helping any.
Larger turbos can help reduce egts at high engine speeds such that one might pickup an additional 25 to 50 usable hp but at the sacrifice of low rpm spool up and turbo durability. We have some new turbos to test and hope to offer some in the first quarter of next year."
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=deere nut link=board=49;threadid=23973;start=0#msg226201 date=1071803921]
[/quote]
Ahhhh, the Mark Chapple line that I beat him up about whenever I get the chance. One thing that TST fails to mention is that their results were garnered from dyno testing, not real world tests where airboxes and exhaust systems will reduce EGTs (if not HP), sometimes by a substantial amount.
As for the lower HP setting box, I doubt you'll see a 80 HP box come out with the injection pulse width. The cost to manufacture the box would be same as the standard 150 HP box. So, buy the 150 HP box, and crank the power down
Rod
[/quote]
Rod
t-boe
01-04-2007 09:35 AM
bauer500
10-12-2004 11:52 PM
Rolngthun
09-30-2003 06:50 PM
