New Lift and tires with vibration
Old 07-06-2008, 12:23 AM
acman's Avatar
Going back on Monday.
Old 07-06-2008, 07:59 AM
hickeyman's Avatar
If it was your carrier bearing you would notice it vibrating when starting out then it would stop at higher speeds.I had to drop mine down 1.5" to stop vibration on mine.
Old 07-06-2008, 09:45 AM
acman's Avatar
The noise starts at 45 MPH and it gets louder.
Old 07-06-2008, 01:46 PM
acman's Avatar
Well after reading all the responces I will first try ajusting the caster to reduce the pinion angle and if that does not work i will lower the transfer case. Does lowering the case put more stress on other componates like motor mounts ?
Old 07-06-2008, 02:11 PM
Ram Daddy's Avatar
In my opinion , it doesn`t move it enough to cause any other problems.
Old 07-06-2008, 02:13 PM
UnrulyNFS's Avatar
I would pull the front shaft first to see if its coming from there before messing with castor.
Old 07-06-2008, 03:55 PM
acman's Avatar
I tried, got the rear loose but could not break the tork without stripping them. there is not enough rom to get strait on the bolt.
Old 07-06-2008, 05:28 PM
Ram Daddy's Avatar
been there ...done that too
Old 07-09-2008, 08:57 PM
acman's Avatar
whats the proper caster for 06 megacab ?
05-29-2009 10:24 PM
dodgedsl03
01-18-2007 10:08 PM
sakisaki400
23
12-31-2006 10:17 PM
Captain
09-09-2005 12:16 AM
Quick Reply: New Lift and tires with vibration
