New HTTss Turbo
New HTTss Turbo
Has anybody heard about the new HTTss Turbo coming out
i talked to the guys there at HTT They told me that it spools quicker
the ss turbo holds up to about 600 degrees more then there other HTT turbos. it's going to be nice
member HeberRam has one in his truck right now...ask him what he thinks about it (I think he is beta testing it so he may be sworn to secretsea SP?)
I would like to hear some info on it too please today is the first time I have heard of it. 600*more then any other turbo is a lot of heat???
wouldn't you piston's be melted at that point anyway???
it's going to hold up to 2100 degrees.
Sounds like ss is Stainless Steel since this matches with the melting point....I would think that the bearings are SS also. The pistons are exposed to heat only during their firing order combustion then they are cooled twice with oil then fired up again. The turbo is heat soaked pretty quick and stays hot. The high pressure oil flow just cools and lubricates the bearings. The hotter the turbo the hotter the return oil will be getting before it drops to the pan for recirculation. ks
I like the way you put that ABC
When I talked to em in late Dec, or early Jan I was told 2 weeks or so. Finaly I got tired of waitin. I am interested in how they perform but I dont know that I will ever have one. FWIW I was told they would cost 125-150 more than the standard 71 but who knows, that was almost 3 month ago so I am sure a lot has changed.
I think that the main reason that they are going to a Stainless Steel housing is because SS holds heat better. Less heat dissipation in the exhaust housing means that the exhaust gases will flow better keeping the turbo spooled better. Just my $.02
Snoxracer
Snoxracer
hoot
04-16-2008 10:08 PM
HeberRam
54
04-24-2007 08:34 AM
kawi600
06-21-2006 06:48 AM
HOHN
28
07-06-2004 04:38 PM
