new clutch
new clutch
I just put my new clutch in on friday 3600 dd. and the pedal on the clutch grabs twards the top of the pedel or end of stroke. this does not seem normal to me or is it to be expected??
not sure about the dd but on my ofe with the upgraded hydro there is a plastic pin on the clutch pedal. You can remove the pin and rotate the shaft to adjust travel.
yea I have that upgraded hydrolic system. I adjusted that and it still was the same just longer pedal travel. you only have to push in the clutch like an inch to two inches and the clutch is disengadged. no matter how much you adjust the rod that hooks to the pedal.
with the 3600 dd, while idleing in N should there be noise coming from the clutch. ther is noise when you push the clutch in but that is normal I think with a dd clutch.
Yes, a DD is gona be louder in most all circumstances when compared to a stock clutch.
Mine makes more noise with the clutch pedal depressed but I THINK the 5600s are noisier when in nuetral and pedal released when compared to the G56s
Well I will just roll with it then. Seems to be working ok I was just concered about were the clutch started to grab at. As you all know it is a spendy up grade and I did not wan't to harm it by weiring it out to fast..
Derek Crowl
08-20-2013 10:43 PM
Backwoods Bumpers
11-20-2007 08:01 AM
WACTD
07-25-2006 11:41 AM
