New Best 12.48 @ 112...need help launching
On my 05 if I am bracket racing I will leave at 15psi. This will net about a 1.65 60' and an 11.20 e.t., and is very consistient. For heads up, I launch at 18psi, and will end up with a 1.58-1.59 60', and run ~11.08. This is on toyo proxies, and the truck weights 7150 with me in it. This was with the Flux 4.7 injectors.
The thing that bothers me about your run is the mph. With the power you should be making, you should be closer to 120. What boost are you seeing going down the track? When does it shift to OD (before the 1/8 mile?)? What is your rail pressure?
Paul
Paul
DTR 1st Sergeant
Remembering that boost is really a measure of restriction, the head work removes restriction and thus you get better flow.
Using the fire hose analogy, if a small diameter fire hose requires (using purely imaginary numbers to make the point) 100 psi to force 100 gph of water through it and you went to a 50% larger hose (remove restriction) you could then push the same 100 gph of water with say only 50psi.
I haven't priced those out yet, but I do like the design. Everyone seems to go with the round tubing, but I kinda like to be different. I like the looks of these 2" square tubing bars with Ballistic ends and tube adapters that Adam Harman (Bigyellowiron) built.
These would definitely be a cheaper route. Any suggestions on what the desired length should be for my QC long bed?
Jared
Thanks for the advice guys! I threw a set of traction bars on and put on some all terrain 285 tires, aired down to 30psi. I boosted up to 20psi and was able to get my 60ft time down to 1.73 seconds which brought my 1/4 mile time down to 12.02 seconds at 112.92mph. This was this evening at Rocky Mountain Raceway, 4200ft elevation, and at about 90 degrees outside. I'm gonna run on Friday at the midnight drags hoping the cooler outside air will help me dip into the 11s.
Anyone know why I'm still only trapping at 112, even though I'm almost half a second faster? That run was with TNT/R tune on SW8, torque management on 1, shift defuel off, timing on 2, pressure on 3, and wastegate set to off.
Jared
Jared
stationarycoppe
08-06-2012 04:30 PM
TDX
08-24-2009 12:01 AM
jmccart
54
03-10-2008 06:29 PM
