need tranny help
need tranny help
ok so here is my question i have a nv5600 in my truck but i broke it so now i have to one fix it or two put a auto in it the price to rebuild and install is about $4000 so i was wondering the cost of the 47rh ??? the one with no computer control so it would be the easyist to put in so how much would a moderately built tranny be and the pros and cons
Putting an automatic in where a Standard was is a lot of work. Besides the tranny you will need a flywheel, cooler, cooler lines, linkage, driveshaft, crossmember, and probably a whole lot more.
I would try to find a good used or find a standard only rebuilder near you. You will probably come out cheaper in the long run staying with what you have.
i think the crossmember is the same the driveshaft the local place does them cheap IF its different cooler and lines are not a big deal and linkage i was thinking of a b&m gate shifter
Black Dog
12-03-2009 08:18 PM
Common
06-09-2008 12:16 PM
PapaPerk
11-29-2004 09:13 PM
